I have a simple board, I had added a bottom ground plane. The bottom component pads properly “part the green sea”. However when I add a trace, that trace changed from the component pad netclass (in this case 3.3) to Gnd.
I can’t imagine a setting that would do this but don’t know.
And if I try to edit the properties of the trace in question (back to 3.3) it won’t change.
Any thoughts?
Thanks
John
Version Info:
Application: KiCad PCB Editor
Version: (5.99.0-9949-gc5c348538e), release build
wxWidgets 3.0.5
libcurl/7.71.0 OpenSSL/1.1.1g (Schannel) zlib/1.2.11 brotli/1.0.7 libidn2/2.3.0 libpsl/0.21.0 (+libidn2/2.3.0) libssh2/1.9.0 nghttp2/1.41.0
Platform: Windows 10 (build 19041), 64-bit edition, 64 bit, Little endian, wxMSW
Date: Mar 22 2021 10:02:28
wxWidgets: 3.0.5 (wchar_t,wx containers,compatible with 2.8)
Boost: 1.73.0
OCE: 6.9.1
Curl: 7.71.0
ngspice: 34
Compiler: GCC 10.2.0 with C++ ABI 1014
KICAD_SCRIPTING=ON
KICAD_SCRIPTING_MODULES=ON
KICAD_SCRIPTING_PYTHON3=OFF
KICAD_SCRIPTING_WXPYTHON=ON
KICAD_USE_OCE=ON
KICAD_SPICE=ON
