I haven’t played with this useful looking tool yet, but I wonder if drawing two rectangles in EdgeCuts around all the boards (ID and OD of a frame) and then using the ECO1 layer to connect them to the inner boards would generate the frame that you want.
Whipping up this example also made me think of two missing features:
There should be a way to avoid the drill line on one side of the tab, so the tab will stay on the frame.
There should be a way to manually create a drill-line across the frame, so the frame can be broken in line with the payload pcbs without joining multiple frame parts with tabs.
The Mousebites seem to be in the clearance area of the filled zones, which might expose copper at the sides of the PCB’s.
Why is the clearance not maintained there?
Forgot to manually re-generate the zonde boundaries? or the Mouse bites do not get registered by Kicad ?
Is there a way to adjust the Mouse bite properties (hole size, distance number of holes?)
My current KiCad version does not have scripting enabled. I’ll come back to try this later.
I did not refill the zones, so that would not be a problem.
I have not tried the kicad scripting, this utility is a stand-alone program that reads and writes kicad_pcb files, there’s a demo video here: https://dren.dk/kicadutil.html
Yes there are options to specify hole size and spacing:
Usage: java -jar ku.jar pcb panel [–fillet=<filletRadius>]
[–hole=<holeDiameter>] [–inset=<holeInset>]
[–pitch=<holePitch>] [–width=<width>]
Creates mouse-bites out of Eco1.User lines where they cross Edge.Cuts
--fillet=<filletRadius>
The radius of the routing bit, a larger fillet will
cause a thinner tab for the same width,
Default is 1.3 mm to accommodate the typical 2.5 mm
router bit without hitting both PCBs
--hole=<holeDiameter> The diameter of the mouse-bite holes,
Default is 0.8 mm
--inset=<holeInset> The distance from the edge of the board to the center of
Default is 0.25 mm
--pitch=<holePitch> The center distance between mouse-bite holes to attempt
hitting,
Default is 1.3 mm
--width=<width> The distance from the middle of the tab to the place
where the routing fillet starts,
Default is 2.5 mm, if the fillet radius is 1 mm, then
you’ll end up with a 3 mm wide tab and
5 mm from flat edge to flat edge at the root of the
mouse-bites
Here’s how the bites look after refilling the zones:
Here’s the output panel, notice the tabs that are solidly attached to the frame and the break-lines in the frame itself that are aligned with the mouse-bites that attach the payload pcbs to the tabs:
