I know, it’s not the perfect category, but I did not know which one would fit best.
So I’m working from time to time on rather complex projects and I’d love to see a time-lapse video of my routing process. I tried it before by taking a screen shot in regular intervals but you have to zoom and pan to exactly the same position every time and you simply just forget it.
So what I’m wondering is this: is it possible to start PCBNew in the background, let it zoom and pan to a defined position and print/plot the layout or take even a screenshot without disturbing my normal work?
It’s not very important, I’m just curios if anybody has an idea how to manage this.
… and this happening in the background in a second instance of KiCAD (or something like this - maybe there is a possibility to render the contents of the .kicad_pcb file) so that I can continue to work unimpeded on my project.
but can’t make it work right now. And I wouldn’t take a snapshot every second. If I work around 100h on a PCB even a snap every 5 minutes is way to often
In combining these snapshots I don’t see much of a problem, batch processing images is pretty easy on Linux IMHO.
how about setting your autosave delay low, and running a script in the background to autocommit to git? then you’ll be able to roll back to any point if needed, instead of just plots.
of course, you’ll still need to figure out the rendering, but this could be done now at your leisure.
