Three position switch footprint
I was wondering if anyone knew of any single pole triple throw switche footprints, I tried looking online but there aren’t any from what I can find.
There are probably as many footprints as manufactured switches.
If the switch is PCB mounted, you will have to have either a Data sheet or an actual item and then make your own footprint. This is not difficult, but first you need a personal library in which you can place the created footprint. See my FAQ explaining how to create libraries if you do not have any yet. If you then need help using the footprint editor, please ask in this forum.
If it is a panel mounted switch, all you need is a four pin connector.
I know exactly what you are looking for!
Voltage, amparage, size and IP rating. Even the color of the knob. Unfortunately, that switch doesn’t exist. No need to look for that footprint.
