Hi, i simple created copper area (GND) and specify in its property to use thermal supports.
Automatically kicad add thermal supports in all GND pads, obviously, but in some pads i obtain this result (see photoes).
A thermal supports connected to nothing, i’m not able to remove this, even in gerber files because it not appear in a single line but in a surface.
Thank you very much.
I was looking in 6.00 for a zone keepout. Maybe that is now done with a “rule area.” Can you try adding “rule areas” to either side of the pad so that KiCad does not add thermal relief spokes pointing in that direction?
