Till now (my old Protel) I defined (except default) two component classes : Medium and Big.
For default I defined thermal relief width of 10mils, for Medium 20 mils and for Big 30 mils.
I have done some experiments (KiCad 4.0.7), and have same questions:
Do I have to set thermal relif width (if different than filled zone settings) separatelly for each pad connected to filled zone?
Is it possible to edit pad parameters if its footprint is locked?
I have defined one filled zone (at bottom) and there I have two throuh hole elements and each has one pad connected to that GND zone.
What decides that one (squere) pad is connected by horizontal and vertical lines) and second (circular) by 4 lines at 45 degree?
I canāt find at footprint level the possibility to edit thermal relief width.
Why do you suppose I havenāt done that? I have done some experiments (as I have written at the beginning). I just wonted to ask short, precision questions without too much useless speaking.
I am investigating KiCad to find the ways I will use for my typical tasks. At that moment I see that when Iāll put the GND filled zone on top I will have to left thermal relief according to small (0603, SOT323) elements as they are the most of all connected to GND. So I will have to change the relief settings for all bigger elements (if Iāll not find the way for elements than pads) connected to GND. They (like terminal blocks) are frequently locked. Designing PCB for DIN mounted box I also lock high elements (like electrolitic capacitors) to avoid incautious move of them to the region when the box is not enough high.
I have tried and failed to get to edit pad of locked footprint. Few days ago I coudnāt find the way to copy graphics in lib edit, asked and got the answer how to do that so I assume that here also may be it is possible but I canāt find the way.
Only because it sounds so trivial. Either you can edit a pad parameter (do you mean āpropertyā?) or you canāt. Locking should affect only the position, not other properties.
In 5.0RC itās in the footprint Properties dialog.
I have only 5.0RC installed, Iām sorry if I have given wrong information. I was quite sure that the zone connection was similar in 4.0.7.
OK, I installed 4.0.7 as a flatpak package. It seems to behave like 5.0RC. The footprint āPropertiesā is called āParametersā in the legacy view/toolset mode context menu, but the dialog is identical, and Pad connections to zones can be found easily. Also changing individual pads is possible even if the footprint is locked.
Yes. I donāt think pad properties are locked but how to get to edit them. When I press āEā on pad of unlocked footprint I have pad properties window opened, but on locked footprint I have footprint properties window opened. Of course I can unlock, edit then lock but I am looking for shorter way, as Iāll do it with the serie of pads.
In 4.0.7 in footprint properties I can only decide how pad connections to zone are done (like zone settings, Solid, Thermal, None) but not the connection width.
I was thinking about to look at V5 but I have spend some time looking through menu at https://kicad.org/ and donāt know how to get to place I could download V5. Iāve only found some information under Contribute/Developers about getting the source, but Iāll certainly not compile anything.
Is it hidden or Iām blind?
It looks like you can use the legacy (default) canvas (view/toolset) and then open the context menu on top of a pad. Thereās Pad and Footprint submenus. In the OpenGL canvas you canāt open Pad properties for some reason.
Do legacy means F9? I didnāt checked it. As the only reason I am interested in KiCad are the properties of routing under F11 I just used F11 and didnāt considered switching the view back to the old version (to tell you the truth I really forgotten that there are other views).
After F9 in context menu on pad of locked footprint I have first position āPad 2 on⦠of S2ā and then Edit Pad, and also pressing E gets me to Pad Edition.
This is the way I expected it is but I canāt find. Thanks.
So to make those changes for thermal reliefs width I have to temporary switch to F9.
But I have nowhere found the word āParametersā so may be we are speaking about different things.
