The Eeschema of the beta 5.99 is no longer available, with kicad-msvc.r22985.450b0c9e27-x86_64.exe
Hi all,
The nightly build version used last week is still normal, but there is a problem with the ‘kicad-msvc.r22985.450b0c9e27-x86_64’ downloaded today.
It is correct to open the schematic diagram from a *.kicad_pro file with kicad, but it will not work if you open the *.kicad_sch file directly with Eeschema.
From your title I first thought that Eeschema was not working at all in your latest KiCad, but if that was true, then it also could not be started from KiCads project manager.
Could it be that just the file association between *.kicad_sch and Eeschema does not work?
Does it work if you first start Eeschema in “Stand alone” mode, and then open a schematic?
Thanks Reply,
It is confirmed that Eeschema’s standalone mode does not work. No window will be displayed in Windows 10 64bit, but it can be found in the task manager.
2021-06-24 20_57_45-Window
I just re-verified the previous version. Until yesterday’s “kicad-msvc.r22977.3269f45776-x86_64.exe” is still normal, only today’s “kicad-msvc.r22985.450b0c9e27-x86_64.exe” Eeschema cannot work.
I think JP fixed this today. See if it works in tomorrow’s build.
Full disclosure: if it’s what I’m thinking, I’m the one that broke it. :frowning:
450b0c9e is already JPs commit though?
Hmmm… you are correct indeed. Although I don’t understand how the nightly got built in the middle of the day…
The day and night is relative no? :wink:
No, I live in GMT. All you other folks just have your clocks set wrong… :wink:
Generally Meaningless Time?
Just installed the latest kicad-msvc.r22992.232ffe97be-x86_64.exe, it has been working normally.
Thanks everyone for your hard work! :+1:
:grinning:
