Kicad Version 8 under windows, (it was already the case with version 7)
I’ve got in the schematic a text variable for the Version of my board (FVersion).
And I use it in the schematic editor, for some text. and In the PCB editor, for some silscreen text.
When I update it in the schematic editor (file->schemaic setup->text variables), it does not update in the pcbeditor. Even if I do an update PCB from schematic.
To force the update, I must close kicad and reopen it.
I think this is a bug of Kicad.
But are you guys having the same issue, and may be someone as an easier workaround.
Yes it was already the case on V7. But I’ve almost screwed a board order because of it. so I’ve decided that it needed to be reported, and hopfully fixed
Done,
However, the description are not exactly the same.
In the #14360 it talking about automaticaly updating the variable in the PCB.
But I my case, I’ve done an update PCB with schematic action. So there is no question of doing a silent update of the variable which could create some issue (as discussed in the #14360 bug)
