I don’t seem to be able to create a text object on the silk screen or user drawing layers larger than 12.7mm or 0.5". Trying to use a larger value in the text size entry boxes end up at 12.7mm after you hit OK. Is this a hard coded limitation, or is there some setting I can change to allow larger text sizes? (This is with v4.0.4)
I’m not sure, I’m working on a way to use KiCommand on (which should work on v4.0.7 or nightly) to make the text as big as you need. It will end up something like:
textobj selected topoints todrawsegments 2 scale
And it will convert all the text to line segments, so it wouldn’t be editable as text after that.
Edit to add:
I had already created a command texttosegments. See if this works for you:
