Text Revision Question
In Pcbnew’s Page Settings window there is a field called “Revision” . I’d like to capture that revision string and insert the string in some text in my silk screen layer. Is there a way to do that? Every time I change the revision number, then I have to manually edit the text. I’d like to avoid that.
So, is there something like this in Kicad I could use with some text in my silk screen layer?
“Board Revision $REVISION”
v5.99 has this
20char
