I’m running KiCad 6 on KDE/Arch Linux. Generally working great, but some fonts are small and some are normal size:
Even in the preferences dialog above, the menu tree is small, but the dialog contents are normal size.
In KDE, I’m running the following display settings:
This works pretty well – for instance, below is a dialog in libreoffice:
Does anyone else have experiences with KiCad + KDE?
Thanks!
This is an issue with WxWidgets and its support of high DPI monitors. I’m not aware of anything that can be done other than wait for a future version of WxWidgets that addresses the problem. There’s a bug on gitlab about it if you’re curious.
