Hello, I am testing the simulator with 7.99 on a win10 Laptop
This already works very well and stable but I found 2 things about which I am not sure if they are intentional.
When I change values in the schematic they will be used for the next simulation in the simulator window. But when I change the circuit I have to close and reopen the simulator to make the changes valid.
When using a differential voltage probe I have to assign a dummy resistor to the output pin to make this signal appear in the simulator. In 7.0.9 I can simply use a “no connection cross”.
Greetings, Chris
