Testing Build failures
The 31st is missing
A bug was fixed yesterday that was bothering me
Still no new builds and there are errors here:
https://jenkins.simonrichter.eu/view/KiCad%20Status/job/windows-kicad-msys2-5.1/
Paging @GyrosGeier
It seems that the definition of the PKGEXT environment variable changed with the last mingw update. That is probably trivially fixable, let’s see…
Needed an extra change to properly find ngspice.
The patch build has succeeded, proper images will happen once !324 has been merged.
Should I raise an issue for this so that it can be assigned the 5.1.7 milestone, I see a patch from you last week stuck for 3 months before commit
No, the patches that are stuck for a long time are controversial. The 5.1 fix got merged two hours ago, in five hours the scheduled build will run, so in eight hours there should be binaries unless I forgot something else (like adding libssp, but that should have been picked up by the fixes for the regular nightlies).
