Running v5.1.10 and would like to know if there is a way to temporarily remove/disable the 3D model when viewing the PCB with the 3D viewer?
I want to view the tracks under the component and the only way I’ve found to do this is to delete the mdel under foorprint properties / 3D settings. But then you need to browse to the model to add it back again which is painful if you want to view under lots of components.
Would be nice if the preview tick box was linked to the 3D viewer. Unless I’m missing something
KiCad version:
Application: Pcbnew
Version: 5.1.10-88a1d61d58~88~ubuntu20.04.1, release build
wxWidgets 3.0.4
Platform: Linux 5.4.0-74-generic x86_64, 64 bit, Little endian, wxGTK
Boost: 1.71.0
Curl: 7.68.0
Compiler: GCC 9.3.0 with C++ ABI 1013
USE_WX_GRAPHICS_CONTEXT=OFF
USE_WX_OVERLAY=ON
KICAD_SCRIPTING=ON
KICAD_SCRIPTING_MODULES=ON
KICAD_SCRIPTING_PYTHON3=ON
KICAD_SCRIPTING_WXPYTHON=ON
BUILD_GITHUB_PLUGIN=ON
KICAD_USE_OCE=ON
KICAD_USE_OCC=OFF
KICAD_SPICE=ON
