System freezing opening KiCad Library
I have big issue with KiCad under Ubuntu 24.04 No matter if I install KiCad V8 as snap or KiCad V9 as .deb, the whole system freeze when I opening the Standard Library. I work on a Laptop with 4 Gb Memory. That’s a pity, because I can’t work with KiCad like that.
Using Wayland? Try switching to X11: https://linuxconfig.org/how-to-enable-disable-wayland-on-ubuntu-22-04-desktop
I have X11 installed
This Morning I installed KiCad V7 and made some test and it seems KiCad run without freezing. At least with the few tests I did
Of course it would be installed, but are you using it? Can you post full KiCad version info?
Version 8 as snap and Version 9 as .deb doesn’t work
No problem here the version info (this version works until now):
Version: 7.0.11+dfsg-1build4, release build
wxWidgets 3.2.4
FreeType 2.13.2
HarfBuzz 8.3.0
FontConfig 2.15.0
libcurl/8.5.0 OpenSSL/3.0.13 zlib/1.3 brotli/1.1.0 zstd/1.5.5 libidn2/2.3.7 libpsl/0.21.2 (+libidn2/2.3.7) libssh/0.10.6/openssl/zlib nghttp2/1.59.0 librtmp/2.3 OpenLDAP/2.6.7
Platform: Ubuntu 24.04.2 LTS, 64 bit, Little endian, wxGTK, ubuntu-xorg, x11
Date: Apr 1 2024 06:00:58
wxWidgets: 3.2.4 (wchar_t,wx containers) GTK+ 3.24
Boost: 1.83.0
OCC: 7.6.3
Curl: 8.5.0
ngspice: 42
Compiler: GCC 13.2.0 with C++ ABI 1018
KICAD_SPICE=ON
Replying in order to not get this thread closed, and hopefully, getting a solution.
I have the exact same issue in Debian 12 (KDE plasma 5, X11, nomodeset on) with KiCad 9, indistinctly it is from a deb or flatpak install.
I’ll be thankful If any of you can point me to the possible solution or exact bug report.
