This window is a big table with well-organized data of the schematic. But the window is a popup or something similar. And there is no way to maximize this window or to snap it to the corners, at least on my linux box (Ubuntu/Gnome). Also, popups by default on Gnome, are glued in front of its main window. So it is kind of hard to use it on my system.
So, why this window has to be a popup?
Is there any plan or idea to turn it into a real window?
Interesting. This works normally on Windows and Kubuntu (GTK toolkit but KDE desktop/window manager). As Ubuntu is a supported system, this may be a bug which would be fixed.
I reported this before version 6 and the idea it was cut, maybe it was too much for that time.
The “Electrical Rule Checker” is also the same kind of window. I cannot use the snap tool. The way I used to work (on everything) is to split my single monitor screen in half using Win+Arrow_Right and Win+Arrow_Left so I can do things and check things simultaneously without having to lose time managing windows and moving them around.
Size and position are adjustable, indeed. I am not saying it is fixed.
I am saying that there are no window controls in the title bar. The “Maximize” as we see in any other normal windows is not present. Which means it is not a normal window.
Why don’t we have a normal window here? Any special reason? Maybe because it is easier to control the main window, idk.
The term is modal dialog window. It’s main use is that it blocks the interactions with parent window which spawned it while the dialog is still open. This is usually done to avoid having to keep track of 2 windows and synchronizing state between them.
For example if you open field table from eeschema and then add/remove a component, the field table should get updated.
It’s not impossible but doing this right can be tricky as there are lots of hidden interactions and edge cases to consider in this kind of window synchronization. Usually just not worth the effort so devs make it a modal dialog to guarantee that you only interact with one thing or the other.
