I would like to ask you a question about symbol alignment. Not sure if it’s a bug or feature (of 8.0), so I will ask first.
If I choose the component in selection window (let’s say GND) the space between the drawing and text looks good. But when I placed it into schematic there is a bigger space. So I would say, the alignment is now wrong. The grid is set to 1.27mim and I’m able to move it manually to correct place once it’s placed in the schematic.
Speaking about V7. It is save to have grid in schematic always set to 50mil and use Ctrl (or Shift, writing from memory - not sure) to move texts.
As I have read in V8 (I didn’t installed yet) you can have separate grids settings for symbols and for texts.
I always turn off auto placement. I find it a quite annoying “feature”. Main reason is that by default the value of resistors fits nicely inside it (for EU resistors, not the insane zigzag line), and this is also the default location.
I have smaller resistor symbols and don’t place texts inside and I have all texts at schematic horizontally. For me the best would be if auto placement would be switched off when you place and move symbol, but switched on when you rotate it.
