I’ve run into a situation where KiCAD is arbitrarily moving symbol text. I suspect it’s trying to be helpful but the result is the reverse. I’ve defined a revision symbol to annotate revision changes.
The ## is a newly defined field that will contain the revision indicator. It’s centre aligned so it should fit in the outline nicely when it is set. However, when this symbol is placed KiCAD both moves the field outside of the outline and changes it to left alignment
I see no setting that would prevent KiCAD from doing this destruction. I can obviously change this on each placement but that is work that should not be necessary. Perhaps there is some predefined symbol for this use I haven’t found or some setting that prevents symbol text from being moved (I can think of other circumstances where this is a less than desired thing)
Application: KiCad Symbol Editor (64-bit)
Version: (6.0.10), release build
wxWidgets 3.2.1
libcurl/7.86.0-DEV Schannel zlib/1.2.13
Date: Dec 19 2022 21:23:04
wxWidgets: 3.2.1 (wchar_t,wx containers)
Boost: 1.80.0
OCC: 7.6.2
Curl: 7.86.0-DEV
ngspice: 38
Compiler: Visual C++ 1929 without C++ ABI
KICAD_USE_OCC=ON
KICAD_SPICE=ON
