My suggestion referred to the structure of the symbols in the library file.
Let’s have the look on the symbol structure at this moment:
CMP_NAME
DEF CMP_NAME C 0 40 Y Y 1 F N
F0 “C” 0 140 45 H V C CNN
F1 “CMP_NAME” 0 200 40 H I C CNN
F2 “C_0805” 0 -80 30 H V C CNN
F3 “” 0 -90 10 H V C CNN
F4 “1.8pF” 0 85 40 H V C CNN “Value2”
F5 “50V” 0 -125 30 H V C CNN “Voltage”
F6 “10%” 0 -170 30 H V C CNN “Tolerance”
DRAW
S -40 -50 -20 50 0 1 0 f
S 20 -50 40 50 0 1 0 f
X 1 1 -150 0 110 R 25 0 1 1 P
X 2 2 150 0 110 L 25 0 1 1 P
ENDDRAW
ENDDEF
The same information is in three different places:
here:
CMP_NAME
and here:
and here:
Why is this needed? I don’t know what to say.
But, in the symbol editor, I don’t understand why Kicad, when I create a symbol, don’t allow me to have different names for symbol Name (DEF field) and for Value (F1 field)?
However, after I placed the symbol in the schematic, Eeschema allows me to change the Value.
In this moment, this situation involve for me a double work to change the symbol Value, every time when a symbol is placed into a schematic. Do it one time in my life, it is not a problem, but when I have to do it 1000 times, it could be a problem.
In my opinion it will be a big advantage if symbol editor will allow me to have different names for Name and Value of the symbol.
For example, let’s have a scenario:
Create a new symbol with below Value: C_SMD_0805_1.8pF_50V_10%CeramicC0G_ID1802270001H
The symbol Name will be automatically chosen the same by the symbol editor:
And after the symbol will be placed in the schematic, I have to manually change above long Value with 1.8pF.
If the symbol editor will allow me to set the symbol Value and then, when the symbol is saved, it will ask be for symbol Name (as Footprint Editor does it), a lot of time will be saved when the component will be used in the schematic design.
This is a solution for the problem in below discussion: Symbol lib, same value but different name, how?
Many thanks!
