Hola, soy nuevo en la comunidad.
Estoy intentado crear un circuito y no he podido encontrar un dispositivo, es el Relay LY2N-J de la Omron.
Me gustaría saber si el dispositivo no existe o si existe con alguna especificación distinta.
Hi, I’m new to the community.
I’m trying to create a circuit and I haven’t been able to find a device, it’s the Omron Relay LY2N-J.
I’d like to know if the device doesn’t exist or if it exists with a different specification.
Are you writing about a symbol for the schematic? There are so many parts in the world that it’s not surprising that there is not a KiCad symbol for every part. Perhaps a generic relay symbol will be suitable. Or perhaps you can modify an existing symbol to suit.
I edited your subject to be more useful to people who might find this topic later.
This relay is a DPDT relay. there is a symbol called “Relay_DPDT” in the standard library. But it’s a one part symbol. if you want to separate the coil from the contacts, then you can start from this symbol.
That type of relay is not made for mounting on a PCB.
Gracias por su tiempo al responder.
Gracias por la indicación, perdón envié el dato equivocado, el relay que esta creado para PCB es el MY2N, quiero agregar a la interacción que existen variantes de este relay, estos varían en la cantidad de contactos, si pueden verificar estos modelos: MY3N,MY4N.
If you want me (or most others here) to respond, then put your text though a translating service. There are many people here for who English is not their native language (including me) and dealing with other languages is a nuisance.
