Symbol Editor pins show up in table but not in symbol
I am trying to make a symbol for MP6602 based on the symbol for MP6601. I basically imported the 6601 symbol from Ultra Librarian and changed some of the pins using the table editor.
All pins show up in the table, but some do not show up (I’m assuming hidden?) in the symbol (E.g. pins 3, 6, 8, 10, 17…)
I cannot for the life of me figure out how to unhide these pins. I know there’s a checkbox in the pin properties dialogue, but I can’t get there without having a pin to double-click. I also can’t find a “show all pins” or “unhide all pins” anywhere…
I believe you should be able to rt-click on the table header and enable the “Visible” column. There is no horizontal scroll bar so you may need to make the window wider to see the column.
Very good answer, and thank you. Right-clicking on the table header did allow me to enable a “visible” column. Now, the plot thickens: The “visible” box is checked for all pins!
I think you created/modified a multi-unit-symbol which consists of “Unit A” + “Unit B”. Both pictures from you show only “Unit A”.
So maybe the remaining pins are assigned to another unit. You should switch between the units in the top-toolbar (pulldown-menu on the right-side of top toolbar).
You guys are the best. That was it…
