Its been bugging me for a while now that the pin properties order is not consistent. Should I open a issue for this or is it just me that’s being OCD.
In the symbol editor if you open up a components and edit the pins when pressing TAB to scroll through the properties it jumps around a bit and does not flow from top to bottom.
It’s a pain when having to edit lots of pins. Wearing down my TAB key
Current order is:
pin name
pin number
x pos
y pos
pin length
name text size
number text size
electrical type
graphic style
orient
Application: LibEdit
Version: 5.1.6-c6e7f7d~86~ubuntu20.04.1, release build
wxWidgets 3.0.4
Platform: Linux 5.4.0-37-generic x86_64, 64 bit, Little endian, wxGTK
Boost: 1.71.0
Curl: 7.68.0
Compiler: GCC 9.3.0 with C++ ABI 1013
USE_WX_GRAPHICS_CONTEXT=OFF
USE_WX_OVERLAY=ON
KICAD_SCRIPTING=ON
KICAD_SCRIPTING_MODULES=ON
KICAD_SCRIPTING_PYTHON3=ON
KICAD_SCRIPTING_WXPYTHON=ON
BUILD_GITHUB_PLUGIN=ON
KICAD_USE_OCE=ON
KICAD_USE_OCC=OFF
KICAD_SPICE=ON
