Symbol editor, how fix display hierachy of multiply graphic items?
I need to use a max9112 IC. It is not in default library, so I made a new symbol. I looked up the triangle with inverted and non inverted output from another similar device and Ctrl C / Ctrl V the graphical parts to my symbol.
It looked great, but than I decided to fill the main rectangle so it would be uniform with other symbols in KiCad.
Now it looks like this. I selected the 2 outputs to make them visable. As you can see on the bottom output, they are not visable. I cannot find how I should fix this.
EDIT:
I found that I need to check this box instead of the bottom one, this seems to solve the issue.
afbeelding
Regards :coffee:
Bas
