In KiCad symbol editor I do not understand the difference between
- new symbol → derive from existing symbol
- duplicate symbol
The first one creates an italic name entry in the library.
The symbol graphic in this derived symbol can not be edited.
For my original symbol I have added several new attribute classes (MFG-Name / MFG-part#, …).
I want to derive many new symbols (representing actual components) by having the same symbol, but adding a fixed component value and the MFG data for this part in my attribute fields.
But when I generate a new symbol and select derive from the above original symbol all user created attributes classes are missing. I only find the Kicad default attributes (Reference, Value, Footprint, Datasheet). This is annoying since I have to define the attribute names all over again.
When I just *duplicate the original symbol all the attributes (names and values) are still present. But then it’s an independant symbol that contains it’s own symbol graphic.
Is there a reason why the user defined attribute names and values are not copied for new symbol → derive from existing symbol ?
Could somebody please explain the indended use case for the above two methods of copying a symbol.
I am using KiCad 7.0.8 release build on Windows 10.
I am aware that the pro solution would be to use the new database library feature. But this step is too big for me right now.
