Hi! This is my first participation on the forum. My apologies for any mistake.
I’m creating the symbol and footprint of Unictron’s AA088 TELA chip antenna (https://www.unictron.com/wp-content/uploads/Unictron_AA088_GNSS_Chip_Antenna_F.pdf). The problem is that pin 1 of the TELA chip antenna family is both connected to the feed point and ground, causing a short circuit. This is done on purpose. The idea is to form a loop around the antenna so that the ambient ground can be used to increase the radiation area, and therefore, the electrical performance of the antenna (https://www.unictron.com/technology/tela-type-chip-antenna/). However, this will create problems for the DRC, right?! Is there a way to create these footprint and symbol so as to avoid problems with the DRC?
For the symbol, I just indicated the connection to ground, as I think I cannot create a duplicate pin.
The footprint is as below (drawn with the aid of the Custom Shape Primitives). I did not draw the grounding pin and the feed point (signal input) by extending pin 1 to the border of the keep out zone. I don’t know how to deal with this short circuit.
