I’ve made a simple design that I originally used an RCA jack as the output - the footprint was fine (downloaded models from Mouser for part RCJ-014).
I’m now modifying the original by replacing the RCA jack with the generic 1x2 pin header. I assigned the footprint and updated the PCB from schematic, but the 1x2 pin header footprint is nowhere to be found.
BUT … it does briefly appear when I use the Freerouting plugin. So it’s there … the Freerouting plugin shows it, but Kicad refuses to.
SOLVED: I had to quit Kicad and restart. So this is a bug?
Application: KiCad Schematic Editor arm64 on arm64
Version: 8.0.6, release build
Platform: macOS Sonoma Version 14.6.1 (Build 23G93), 64 bit, Little endian, wxMac
OpenGL: Apple, Apple M2, 2.1 Metal - 88.1
