Swap Layers in PCB editing
Hi.
Having some troubles with Swap Layers in PCB editing.
I am probably doing something wrong.
I select a trace then I call Edit/Swap Layers. But i cannot do any swap action. I always have this figure, that does not allow to do so much.
Fig15.
I do not see any way to set the swap layers.
Thanks to anyone can help me to understand where I am wrong.
Does this help ?
Once you have selected the “to” layer . . .
another click should give you a drop down to select the destination layer . . .
Swap layers swaps the entire layer not just what you have selected . . . if you just want to change the layer of a selected track use it’s properties.
It helps. Thanks a lot. :slight_smile:
