Hello I am using MacBook, Inkscape 1.1, with plugin SVG2SHENZHEN 0.2.16 with Kicad 6.0.
I can’t export an Inkscape svg file using SVG2SHENZHEN to Kicad. I watched this video Drawing PCBs with Inkscape Creating printed circuit board designs using Inkscape, SVG2Shenzhen and … - YouTube
When I Export using SVG2SHENZHEN I see ‘CHOOSE PATH TO EXPORT’ box. I don’t know how to direct this to Kicad as a PCB, I also get an error message saying.
Inkscape has received additional data from the script executed. The script did not return an error, but this may indicate the results will not be as expected.
export.py:224: DeprecationWarning: Effect.OptionParser or optparse has been deprecated and replaced with argparser. You must change self.OptionParser.add_option to self.arg_parser.add_argument; the arguments are similar.
self.OptionParser.add_option("–path", action=“store”, type=“string”, dest=“path”, default="~/", help="")
export.py:225: DeprecationWarning: Effect.OptionParser or optparse has been deprecated and replaced with argparser. You must change self.OptionParser.add_option to self.arg_parser.add_argument; the arguments are similar.
self.OptionParser.add_option(’-f’, ‘–filetype’, action=‘store’, type=‘string’, dest=‘filetype’, default=‘jpeg’, help=‘Exported file type’)
export.py:226: DeprecationWarning: Effect.OptionParser or optparse has been deprecated and replaced with argparser. You must change self.OptionParser.add_option to self.arg_parser.add_argument; the arguments are similar.
self.OptionParser.add_option("–crop", action=“store”, type=“inkbool”, dest=“crop”, default=False)
export.py:227: DeprecationWarning: Effect.OptionParser or optparse has been deprecated and replaced with argparser. You must change self.OptionParser.add_option to self.arg_parser.add_argument; the arguments are similar.
self.OptionParser.add_option("–dpi", action=“store”, type=“float”, dest=“dpi”, default=600)
export.py:228: DeprecationWarning: Effect.OptionParser or optparse has been deprecated and replaced with argparser. You must change self.OptionParser.add_option to self.arg_parser.add_argument; the arguments are similar.
self.OptionParser.add_option("–threshold", action=“store”, type=“float”, dest=“threshold”, default=128.0)
export.py:229: DeprecationWarning: Effect.OptionParser or optparse has been deprecated and replaced with argparser. You must change self.OptionParser.add_option to self.arg_parser.add_argument; the arguments are similar.
self.OptionParser.add_option("–openfactory", action=“store”, type=“inkbool”, dest=“openfactory”, default=“true”)
export.py:230: DeprecationWarning: Effect.OptionParser or optparse has been deprecated and replaced with argparser. You must change self.OptionParser.add_option to self.arg_parser.add_argument; the arguments are similar.
self.OptionParser.add_option("–openkicad", action=“store”, type=“inkbool”, dest=“openkicad”, default=“true”)
export.py:231: DeprecationWarning: Effect.OptionParser or optparse has been deprecated and replaced with argparser. You must change self.OptionParser.add_option to self.arg_parser.add_argument; the arguments are similar.
self.OptionParser.add_option("–autoflatten", action=“store”, type=“inkbool”, dest=“autoflatten”, default=“true”)
export.py:232: DeprecationWarning: Effect.OptionParser or optparse has been deprecated and replaced with argparser. You must change self.OptionParser.add_option to self.arg_parser.add_argument; the arguments are similar.
self.OptionParser.add_option("–debug", action=“store”, type=“inkbool”, dest=“debug”, default=False)
export.py:736: DeprecationWarning: Effect.affect is now Effect.run(). The output argument has changed.
e.affect()
export.py:336: DeprecationWarning: self.args[-1] is now self.options.input_file.
curfile = self.args[-1]
Traceback (most recent call last):
File “export.py”, line 740, in
_main()
File “export.py”, line 736, in _main
e.affect()
File “/Applications/Inkscape 2.app/Contents/Resources/share/inkscape/extensions/inkex/deprecated.py”, line 183, in affect
return self.run(args=args)
File “/Applications/Inkscape 2.app/Contents/Resources/share/inkscape/extensions/inkex/base.py”, line 131, in run
self.save_raw(self.effect())
File “export.py”, line 313, in effect
self.processExportLayer()
File “export.py”, line 337, in processExportLayer
layers = self.get_layers(curfile)
File “export.py”, line 537, in get_layers
if layer_label_name in self.layer_map.iterkeys():
AttributeError: ‘dict’ object has no attribute ‘iterkeys’
