I think this is the right place for this:
I made a 3-lead SMD footprint, pin 1 a rectangle pad, pins 2 and 3 “Oval” pads. Placed on PCB BACK SIDE. Exported SVG B.Paste PCB layer only.
The Oval pads don’t export right. Exporting renders each Oval pad in Paste layer as nothing more than a straight axial line the axial length of the pads.
I noticed this behavior first in a browser-rendered stencil-making house pre-order check. FreeCAD running locally confirms it. PCBnew, however, renders the oval pads in Paste layer correctly as oval pads, so you’ll never catch the problem unless you screen render the .svg Paste layer files before making your stencils.
The workaround: I changed the footprint’s Oval pad styles to Rounded Rectangle styles with 50% rounded corners, and now the PCB with that updated footprint exports the Paste layer pads properly in svg.
Therefore, I am happy with my footprint workaround of making Rounded Rectangle pads with 50% rounded corners instead of Ovals. Others might need this info, so I’m posting it here. Thank you for reading. I doubt I’ll follow this thread much since I don’t need to.
Ken
Export SVG file settings:
Default pen size: 0.0254 mm
Print mode = Color
SVG Page Size = Board area only
Printed board edges = checked
Print mirrored = not checked
Pagination = One file per layer
Application: ModEdit
Version: 5.1.4-e60b266~84~ubuntu16.04.1, release build
wxWidgets 3.0.2
libcurl/7.47.0 OpenSSL/1.0.2g zlib/1.2.8 libidn/1.32 librtmp/2.3
Platform: Linux 4.4.0-53-generic x86_64, 64 bit, Little endian, wxGTK
wxWidgets: 3.0.2 (wchar_t,wx containers,compatible with 2.8) GTK+ 2.24
Boost: 1.58.0
Curl: 7.47.0
Compiler: GCC 5.4.0 with C++ ABI 1009
USE_WX_GRAPHICS_CONTEXT=OFF
USE_WX_OVERLAY=OFF
KICAD_SCRIPTING=ON
KICAD_SCRIPTING_MODULES=ON
KICAD_SCRIPTING_PYTHON3=OFF
KICAD_SCRIPTING_WXPYTHON=ON
BUILD_GITHUB_PLUGIN=ON
KICAD_USE_OCE=ON
KICAD_USE_OCC=OFF
KICAD_SPICE=ON
