I made a small error I believe. The ERC clearly shows what I did wrong. I apparently should have used the prefixes on the bus side as well so 1.A, 2.A etc.
However…the strange part is that the board editor actually understands all the connections. KiCad sure is smart. Highlighting net between schematic and board does not work. But the board passes DRC with flying colors.
I think it is strange that I have 18 critical Errors in the schematic, and still end up with a good board. But you know what they say: If it works, it ain’t stupid ![]()
Kind regards ![]()
Bas
