I’m using the footprint wizard to generate a touch slider and I am quite happy with the results (thanks to the creators of the script! )
However, when trying to import this PCB with StepUp into FreeCAD, it seems that the trapezoid pads are not supported and they get transformed to rectangular pads.
From this:
To this:
It is not a big problem, as it is just a visual aid for the mechanical guys, but it would be nice if it would look like the real thing. Does anybody know a work around to make it work? would it be easier to create the footprint from scratch in KiCAD or even FreeCAD to achieve it ? @maui Any suggestions ?
StepUp Log when importing tracks:
FreeCAD build date: 2019/10/22
tracks version: 1.1
py3
kicad_parser_version 1.1.2
py3
making copper layer F.Cu...
making holes...
pad holes: 0, skipped: 0
oval holes: 0
via holes: 5, skipped: 0
total holes added: 5
holes done
making pads...
trapezoid pad converted to rect
modules: 5
pads: 82, skipped: 0
vias: 5, skipped: 0
total pads added: 87
pads done
making tracks...
making 3 tracks of width 0.25, (0/18)
making 15 tracks of width 0.50, (3/18)
tracks done
making zones...
zones done
done copper layer F.Cu
running time: 1.655sec
making copper layer B.Cu...
making holes...
oval holes: 0
holes done
making pads...
modules: 5
pads: 82, skipped: 82
vias: 5, skipped: 0
total pads added: 5
pads done
making tracks...
making 35 tracks of width 0.25, (0/35)
tracks done
making zones...
making zone ""...
region 1/3, holes: 0
region 2/3, holes: 0
region 3/3, holes: 0
zones done
done copper layer B.Cu
running time: 2.611sec
StepUp Tools version:
PoM not present
using 'Part' container
FC Version 018-4
kicad StepUp version 9.5.3.0
tolerance on vertex applied
applying Materials to Shapes
your home path is C:\Users\uestrada
Links not allowed...
falling from Hierarchy to Compound
kicadStepUp
closed
active :slight_smile:
KiCAD Version
Application: KiCad
Version: (5.1.5)-3, release build
wxWidgets 3.0.4
libcurl/7.66.0 OpenSSL/1.1.1d (Schannel) zlib/1.2.11 brotli/1.0.7 libidn2/2.2.0 libpsl/0.21.0 (+libidn2/2.1.1) nghttp2/1.39.2
Boost: 1.71.0
Curl: 7.66.0
Compiler: GCC 9.2.0 with C++ ABI 1013
USE_WX_GRAPHICS_CONTEXT=OFF
USE_WX_OVERLAY=OFF
KICAD_SCRIPTING=ON
KICAD_SCRIPTING_MODULES=ON
KICAD_SCRIPTING_PYTHON3=OFF
KICAD_SCRIPTING_WXPYTHON=ON
BUILD_GITHUB_PLUGIN=ON
KICAD_USE_OCE=ON
KICAD_USE_OCC=OFF
KICAD_SPICE=ON
thank you!
Wow! Thanks a bunch Maui!
