Hello, I’m trying to troubleshoot an error with importing some of my 3D models using the FreeCAD workbench StepUP. It appears that the only models that aren’t importing correctly are ones that I sourced or made myself.
These models show up correctly in the 3D viewer of KiCad. I added these custom models in by using the footprint editor and aligning the footprints there in KiCad.
Notice that the center button and pogo pins are present in KiCad. I’m not sure why these aren’t being pulled into FreeCAD because my secondary search path is defined as the same file path that KiCad is getting the STEP files for the footprints. I currently only have STEP files there but I tried adding a vrml file for one of the components as well and this did not fix one of the errors.
Your dialog shows to paths: the KiCad’s own KISYS3DMOD and GITCHECKOUT. StepUp should find the first one automatically and the second one you should put in the secondary loc in the StepUp settings. Is that so? What is GITCHECKOUT in KiCad and in StepUp?
The missing models from KISYS3DMOD path are caused by KiCad having 3D model names in all of its official footprints even when there’s no corresponding model. So you have 4 missing models from your own libraries (in that screenshot).
GITCHECKOUT is just the folder that the GitHub desktop app downloads all of my files from github to. I am working with a few people on the project and we regularly push and pull changes through github.
See below that my models are in fact in that folder.
(the Solidworks one are step files)
I guess I can try copying those models to a different folder and seeing if that changes anything.
I am really only concerned with the ones in my github folder. Those are critical to the mechanical design.
I think I verified that the variable being in the KiCad footprint properties is the issue.
I copied the model for the center button out of GitHub and into my documents folder. Then I modified the footprint (KiCad) to look at my documents folder. Next I set my secondary search path (in StepUP) to look at that same place (my documents folder) and then ran the StepUP tool again and it worked for the button.
The button now shows up and there error message says “missing 6 models” now
