Kilted
October 10, 2023, 7:59am
1
Hi All,
New here after coming across from EAGLE so I’m still finding my way about KiCAD but happy with what I’ve done so far. I have designed a board and exporting it to FreeCAD using StepUp. The Board and the Tracks come across without issue but I can’t seem to get the Silkscreens working. I have used the CheatSheet and I am exporting them as DXF in KiCAD but StepUp is throwing a few errors.
Any help to resolve this would be greatly appreciated.
Would @maui be the person to ask?
Thank you
08:36:09 There has been an error:
08:36:09 Unable to identify DXF file version
08:36:09 Running the Python command 'ksuToolsAddSilks' failed:
Traceback (most recent call last):
File "C:\Users\*******\AppData\Roaming\FreeCAD\Mod\kicadStepUpMod\.\kicadStepUpCMD.py", line 4232, in Activated
makefacedxf.makeFaceDXF()
File "C:\Users\********\AppData\Roaming\FreeCAD\Mod\kicadStepUpMod\.\makefacedxf.py", line 184, in makeFaceDXF
File "C:\Program Files\FreeCAD 0.21\Mod\Draft\importDXF.py", line 2766, in insert
processdxf(doc, filename)
File "C:\Program Files\FreeCAD 0.21\Mod\Draft\importDXF.py", line 2136, in processdxf
drawing = dxfReader.readDXF(filename)
File "C:\Users\*******\AppData\Roaming\FreeCAD\Macro\dxfReader.py", line 399, in readDXF
(infile, drawing) = sm.run((infile, None))
cannot unpack non-iterable bool object
Version: 7.0.1, release build
OS: Windows 10 build 19045
Word size of FreeCAD: 64-bit
Version: 0.21.1.33668 +26 (Git)
Build type: Release
Branch: (HEAD detached at 0.21.1)
Hash: f6708547a9bb3f71a4aaade12109f511a72c207c
Python 3.8.10, Qt 5.15.2, Coin 4.0.1, Vtk 8.2.0, OCC 7.6.3
Locale: English/United Kingdom (en_GB)
Installed mods:
* kicadStepUpMod 10.19.5
maui
October 10, 2023, 8:53am
2
hi,
it should be an issue in the FC dxf legacy library…
there is a discussion at FC forum and gh
opened 10:04AM - 05 Sep 23 UTC
closed 06:06AM - 10 Oct 23 UTC
Bug
File format: DXF
Regression
### Is there an existing issue for this?
- [X] I have searched the existing i… ssues
### Problem description
The V1.41 DXF importer library breaks when trying to import or open a DXF file when the file doesn't contain the information about the AutoCAD drawing database version number `$ACADVER`.
As far as I understand the DXF reference information from [AutoDesk](https://documentation.help/AutoCAD-DXF/WS1a9193826455f5ff18cb41610ec0a2e719-7a6f.htm), it isn't a mandatory information
Among others it breaks the import function of [KiCadStepUpMod by easyw](https://github.com/easyw/kicadStepUpMod/issues/181). Trying to load a PCB silkscreen in DXF format yields the error `cannot unpack non-iterable bool object`
In [my comment in KiCadStepUp](https://github.com/easyw/kicadStepUpMod/issues/181#issuecomment-1706299022) I have a rather ugly workaround for the time beeing.
### Full version info
```shell
[code]
Version: 0.21.0.33668 +7 (Git)
Build type: Release
Branch: (HEAD detached at 0.21)
Hash: 41b058e2087de60dc8fef3d3e68c7d0129e13abf
Locale: English/United States (en_US)
Installed mods:
* Assembly3 0.12.0
* fasteners 0.4.59
* InventorLoader 1.4.0
* kicadStepUpMod 10.19.4
* Manipulator 1.5.0
* sheetmetal 0.2.63
[/code]
### Subproject(s) affected?
Other (specify in description)
### Anything else?
17:48:04 opening /home/pde/Downloads/test/test-F_Silkscreen.dxf...
17:48:04 There has been an error:
17:48:04 Unable to identify DXF file version
17:48:04 Traceback (most recent call last):
File "<string>", line 1, in <module>
File "/tmp/.mount_FreeCAXl4oNg/usr/Mod/Draft/importDXF.py", line 2766, in insert
File "/tmp/.mount_FreeCAXl4oNg/usr/Mod/Draft/importDXF.py", line 2136, in processdxf
File "/home/pde/.local/share/FreeCAD/Macro/dxfReader.py", line 399, in readDXF
<class 'TypeError'>: cannot unpack non-iterable bool object
### Code of Conduct
- [X] I agree to follow this project's Code of Conduct
opened 11:06AM - 25 Jun 23 UTC
closed 07:17AM - 05 Jul 23 UTC
Bug
File format: DXF
Missing: example file
Missing: steps to reproduce
### Version
0.20 (Release)
```shell
[code]
OS: Windows 10 Version 2009
Version: 0.20.2.29603 (Git)
Build type: Release
Branch: releases/FreeCAD-0-20
Hash: 930dd9a76203a3260b1e6256c70c1c3cad8c5cb8
Locale: German/Germany (de_DE)
Installed mods:
* Assembly4
* kicadStepUpMod 10.10.4
[/code]
None
When trying to import DXF using the legacy Python importer only generates an error:
13:00:03 DXF libraries need to be updated. Trying to download...
13:00:03 downloading https://raw.githubusercontent.com/yorikvanhavre/Draft-dxf-importer/1.40/dxfColorMap.py ...
13:00:03 downloading https://raw.githubusercontent.com/yorikvanhavre/Draft-dxf-importer/1.40/dxfImportObjects.py ...
13:00:03 downloading https://raw.githubusercontent.com/yorikvanhavre/Draft-dxf-importer/1.40/dxfLibrary.py ...
13:00:03 downloading https://raw.githubusercontent.com/yorikvanhavre/Draft-dxf-importer/1.40/dxfReader.py ...
13:00:03 Traceback (most recent call last):
File "D:\Program Files\FreeCAD 0.20\Mod\Draft\importDXF.py", line 2827, in insert
getDXFlibs()
File "D:\Program Files\FreeCAD 0.20\Mod\Draft\importDXF.py", line 202, in getDXFlibs
import dxfColorMap, dxfLibrary, dxfReader
File "D:\Program Files\FreeCAD 0.20\bin\Lib\site-packages\shiboken2\files.dir\shibokensupport\__feature__.py", line 142, in _import
return original_import(name, *args, **kwargs)
<class 'SyntaxError'>: invalid syntax (dxfReader.py, line 88)
### Anything else?
_No response_
### Code of Conduct
it should be solved … you could try to enable updating legacy DXF library in FC preferences
EDIT: could you share the dxf file? (even PM me if you prefer)
Kilted
October 10, 2023, 9:38am
3
Hi @maui thanks for getting back to me.
The checkbox for enabling the DXF library update is already checked in FC preferences.
Can you send me a message and I’ll forward you the files please?
maui
October 10, 2023, 1:16pm
4
ok, I’ve got the files…
it seems there still an issue in FC legacy importer
we need to reopen the issue
Kilted
October 10, 2023, 3:24pm
5
Thanks Maui.
Are you reopening the issue? Sorry, I’m not sure how bug reporting is done.
maui
October 10, 2023, 6:14pm
6
It seems FC support for legacy dxf importer is moving slowly…
I’ve added an old stable lib to kSU.
Try to update the wb, to see if everything is solved.
Kilted
October 11, 2023, 8:22am
7
Thanks @maui , I have it working now. Thanks for all your help.
system
Closed
January 9, 2024, 8:23am
8
