I know this is not completely on-topic for this forum… but I’m trying to use a STEP model from Phoenix Contact for my project, and when I assign it as the model in the Footprint Properties dialog it shows up…but when I attempt to rotate it into the proper orientation, the X and Z axes behave identically, as if there were only two axes.
I used FreeCAD to convert it to a WRL and the behavior was unchanged.
Can anyone suggest what I might be doing wrong?
pxc_1725669_05_MPT-0-5-3-2-54_3D.stp (504.4 KB)
Seth_h
August 20, 2019, 7:45pm
2
Which version are you running? I do not observe this with your model and 5.1.4
Application: Pcbnew
Version: (5.1.4-34-g6796e8fff), debug build
wxWidgets 3.0.4
libcurl/7.64.0 OpenSSL/1.1.1c zlib/1.2.11 libidn2/2.0.5 libpsl/0.20.2 (+libidn2/2.0.5) libssh2/1.8.0 nghttp2/1.36.0 librtmp/2.3
Platform: Linux 4.19.0-5-amd64 x86_64, 64 bit, Little endian, wxGTK
Boost: 1.67.0
Curl: 7.64.0
Compiler: GCC 8.3.0 with C++ ABI 1013
USE_WX_GRAPHICS_CONTEXT=OFF
USE_WX_OVERLAY=ON
KICAD_SCRIPTING=ON
KICAD_SCRIPTING_MODULES=ON
KICAD_SCRIPTING_PYTHON3=ON
KICAD_SCRIPTING_WXPYTHON=ON
BUILD_GITHUB_PLUGIN=ON
KICAD_USE_OCE=ON
KICAD_USE_OCC=OFF
KICAD_SPICE=ON
Application: Pcbnew
Version: 5.1.4-1.fc30, release build
wxWidgets 3.0.4
libcurl/7.65.3 OpenSSL/1.1.1c-fips zlib/1.2.11 brotli/1.0.7 libidn2/2.2.0 libpsl/0.20.2 (+libidn2/2.0.5) libssh/0.9.0/openssl/zlib nghttp2/1.38.0
Platform: Linux 5.2.8-200.fc30.x86_64 x86_64, 64 bit, Little endian, wxGTK
Boost: 1.69.0
Curl: 7.65.3
Compiler: GCC 9.1.1 with C++ ABI 1013
USE_WX_OVERLAY=ON
KICAD_SCRIPTING=ON
KICAD_USE_OCE=ON
KICAD_USE_OCC=OFF
KICAD_SPICE=ON
Seth_h
August 20, 2019, 8:19pm
4
Hmm… Very similar then. Sanity check: do you have the correct model selected when choosing rotate? (I always forget to do this)
Do any of the other commands (scale, rotate, offset) behave strangely?
eelik
August 20, 2019, 8:30pm
5
Sometimes a screencast would help others see what’s the problem.
If you use FreeCAD you could use StepUp as well, load the model and the footprint and rotate and move the model there and export it to KiCad-compatible step and wrl. They would be correctly placed without doing anything in KiCad.
Rotating that model works fine for me on Windows 10 / KiCad 5.1.4+.
pedro
August 20, 2019, 9:26pm
6
The rotation of the model also works fine for the 3 axes with 5.1.4
My version:
Application: KiCad
Version: 5.1.4-e60b266~84~ubuntu18.04.1, release build
Platform: Linux 5.0.0-25-generic x86_64, 64 bit, Little endian, wxGTK
Well of course today I can’t reproduce the problem at all… must only happen on Mondays
With this (and another) STEP model imported, the 3D view now shows my board fully populated:
system
Closed
November 19, 2019, 1:23pm
8
