I made a circuit layout of couple years ago and just recently got around to having some boards made. The Gerber files I had previously created had problems. There were some stray drill holes outside the board area, no perimeter layer.
I went back to fix things up and make some new Gerber files. However, the online tracer no longer functions. I did find instructions on how to install it locally. I ran it and created a trace, but, I don’t know where the trace wound up.
I finally gave up and just used the old trace as the layout of the board did not change. If I open all the layers with gerbview they all show up, but, when I sent the layers to OSH Lake, there was a problem with the trace file.
Just to complicate things a little more, since that time I had a system problem and had to re-install my OS (linux mint 17.2) and I haven’t reinstalled the tracing application. I do have a backup of my files.
Anyone know where the tracing tool standalone would have stored the trace and what format it might be so I can search?
Other ideas?
I may have used the wrong terrm. I meant the autorouter.
The autorouter results are in a Specctra session file (*.ses).
I can find an .ses file that is about the right date. I see that the old routing file I used was a text file.
I can view the old route file with gerbview, but, the PCP vendor can’t use this.
I cannot open the ses file as a layer in gerbview.
Does something have to be converted or something?
Below is a part of the ses file followed by the txt file:
ses file
(session “Bike Circuit_final_Aug15.ses”
(base_design “Bike Circuit_final_Aug15.dsn”)
(placement
(resolution um 10)
(component tyco2posheader
(place P1 1790700 -1117600 front 90)
(component Panasonic12VRelay
(place Relay1 1206500 -1206500 front 270)
(component Molex3header
(place K1 1536700 -1028700 front 0)
(place K2 1536700 -965200 front 0)
(place K3 1193800 -1384300 front 0)
(place K4 1409700 -1092200 front 0)
(place K5 1422400 -1308100 front 0)
(place K6 1320800 -1384300 front 0)
(place K7 1397000 -1447800 front 180)
(place K8 1739900 -1308100 front 270)
(component BEI15
(place UDCDC1 1562100 -1346200 front 0)
(component bikehole
(place H1 889000 -965200 front 0)
(place H2 1701800 -965200 front 0)
(place H4 1714500 -1409700 front 0)
(place H3 889000 -1409700 front 0)
(place Hole1 1870740 -1667540 front 0)
(place Hole2 1870740 -1667540 front 0)
(place Hole3 1870740 -1667540 front 0)
txt file
G04 This is an RS-274x file exported by *
G04 gerbv version 2.6.0 *
G04 More information is available about gerbv at *
G04 http://gerbv.gpleda.org/ *
G04 --End of header info–*
%MOIN*%
%FSLAX34Y34*%
%IPPOS*%
G04 --Define apertures–*
%ADD10C,0.0060*%
%ADD11C,0.1300*%
%ADD12C,0.0600*%
%ADD13C,0.0700*%
%ADD14C,0.0850*%
%ADD15C,0.2500*%
%ADD16C,0.0500*%
G04 --Start main section–*
G54D11*
G01X0069500Y-045500D03*
G01X0069500Y-042500D03*
G54D12*
G01X0048500Y-044000D03*
G01X0048500Y-046000D03*
G01X0048500Y-048000D03*
G01X0048500Y-051000D03*
G01X0051500Y-051000D03*
G01X0051500Y-048000D03*
G01X0051500Y-046000D03*
G01X0051500Y-044000D03*
G54D13*
G01X0058000Y-039500D03*
G01X0059000Y-039500D03*
G01X0060000Y-039500D03*
G01X0058000Y-037000D03*
G01X0059000Y-037000D03*
G01X0060000Y-037000D03*
G01X0044500Y-053500D03*
G01X0045500Y-053500D03*
G01X0046500Y-053500D03*
G01X0053000Y-042000D03*
G01X0054000Y-042000D03*
G01X0055000Y-042000D03*
G01X0053500Y-050500D03*
G01X0054500Y-050500D03*
G01X0055500Y-050500D03*
G01X0049500Y-053500D03*
G01X0050500Y-053500D03*
G01X0051500Y-053500D03*
G01X0057500Y-058000D03*
G01X0056500Y-058000D03*
G01X0055500Y-058000D03*
G01X0069500Y-049000D03*
G01X0069500Y-050000D03*
G01X0069500Y-051000D03*
G54D14*
G01X0065500Y-052000D03*
G01X0057500Y-052000D03*
G01X0057500Y-048000D03*
G01X0057500Y-044000D03*
G01X0065500Y-049000D03*
G01X0065500Y-047000D03*
G54D15*
G01X0035000Y-038000D03*
G01X0067000Y-038000D03*
G01X0067500Y-055500D03*
G01X0035000Y-055500D03*
G54D16*
G01X0065500Y-046500D02*
G01X0069500Y-042500D01*
G01X0065500Y-047000D02*
G01X0065500Y-046500D01*
G01X0065500Y-051000D02*
G01X0060000Y-045500D01*
G01X0069500Y-051000D02*
G01X0065500Y-051000D01*
G01X0057500Y-048000D02*
G01X0060000Y-045500D02*
G01X0060000Y-039500D01*
G01X0055000Y-041973D02*
G01X0055000Y-042000D01*
G01X0054172Y-041145D02*
G01X0055000Y-041973D01*
G01X0052588Y-041145D02*
G01X0054172Y-041145D01*
G01X0049884Y-043849D02*
G01X0052588Y-041145D01*
G01X0049884Y-046616D02*
G01X0049884Y-043849D01*
G01X0048500Y-048000D02*
G01X0049884Y-046616D01*
G01X0055500Y-042500D02*
G01X0055500Y-050500D02*
G01X0055500Y-042500D01*
G01X0058000Y-039476D02*
G01X0058000Y-039500D01*
G01X0060000Y-037476D02*
G01X0058000Y-039476D01*
G01X0060000Y-037000D02*
It looks like you can only open netlist (.net) files in pcbnew. I don’t see any sort of import feature.
