When we read a netlist in pcbnew , the components are stacked over each other. Is there a way to stack the components in different sets ie for eg: component A,B,C in STACK1 and D,E,F in STACK2. Also, on what criteria is this components stacked?
Open PCBNEW
Import your netlist
Click on the âModeâ button near the upper right of your horizontal toolbar icons right under the âFileâ, âEditâ, horizontal menus. Make sure it is depressed, and says âMode Footprint:â when you hover the mouse over the button.
Make sure you have the âArrowâ tool selected (topmost icon in the vertical list of icons on the right hand side of the screen).
Right click anywhere on the board (except directly on a component), select âGlob Move and PlaceâŚâ ==> âMove All Modulesâ, and click âYesâ at the following prompt.
Done, and you donât even have to create a âPCB_edgesâ layer. It intelligently separates the parts so they have at least a single âunitâ radius (depending on your current grid resolution options) so there is no overlap with other components, as shown below.
Thanks for reply.
But I want to delete some components only after reading netlist. So if they were superimposed seperately , it would have been easy to delete it and work with rest of components. So i asked the question. Can we do it in some manner?
@shahys ⌠can you please not put your posts into these code block backticks http://commonmark.org/help/
It makes reading your posts impossible to me as just the first 10 words are visible and I donât want to scroll sidewaysâŚ
Thanks
Thanks for reply.
Do you have a layout yet or only the components loaded via netlist?
If the latter, hit the âMode Footprintâ button⌠then an empty area in the layout window with the right mouse button⌠and see the screenshot:
