Just wondering through the code and noticed something that probably ain’t an issue, as it’s probably not used but thought I’d ask about it.
The header file specctra_lexer.h defines an enumerated type of tokens. There are some negative ones at the start of the list but then they start from 0 and are listed alphabetically. First four are:
T_absolute = 0,
T_add_group,
T_add_pins,
T_added,
I assume that these tokens match up to the strings defined in specctra.keywords the first four of which are:
absolute
added
add_group
add_pins
These two sub-lists are in a different order. The rest of the lists appear to match up token to string. Like I say I’m only wondering through code so this might be a none issue, but thought I’d mention it.
