So I am wondering how to copy or clone projects and bumped to this.
Is there some new way now in v5.0.0?
Simply copy the folder containing your project. Give the folder a new name and be done with it. (If you want to also rename the project files then you will need to do this manually or using a script. I think that particular post had a script somewhere that does the work for you.)
