I’m using Ubuntu 21.10 + Kicad 5.99. After switching from schematics editor to PCB editor (importing all components from schematics, etc.) I don’t see the components on PCB render (3D viewer), only pads for them:
I’m glad it’s solved for you but I’m still wondering if this should be turned into an issue on gitlab.
Maybe let it sit for some time because of the change eelik mentioned, but if the default path for the 3D libraries is set up wrong, then somebody should do something about it sometime
I just tried on Windows completely from scratch after uninstalling and installing everything, and paths work OK. I can’t say if old setup and the latest nightly update can mess up the 3D models somehow, and this was only Windows, not Ubuntu.
