[SOLVED]What happened to the project templates?
I’m on the latest nightly and cannot create a new project from template.
I do not know since when this happened.
The template files are there, but neither the system nor the user project templates work. Nothing is shown to select from. I even converted everything to the latest file format.
Is there a known issue that I missed?
I did some testing: user templates (as an example) load ok, if you leave the proposed path C:\Users\xxx\Documents\kicad\template unchanged.
When selecting a different path, say C:\Users\xxx\Documents\kicad\6.99\template, no luck.
This is a bug for sure. Will file it in the bug tracker.
There’s already a commit solving the issue.
