[SOLVED] Update from PCB to Schematic?
because it’s possible to update the PCB from schematic, I’m wondering if it’s possible to do the viceversa: to update the schematic from PCB.
Reason: I have a work to do in this way, or it will be much longer/tedious/risky in the normal way.
Just let me know please if there is any possibility to do it;
schematic editor Tools → Update Schematic From PCB
It’s more limited than the forward path. You can change reference designators, net names, values, footprint assignments, and maybe some other things.
Thank you so much. I have to check if customs fields are updated. I will try on a very simple schematic, prior to apply to the real one.
