I found an easier route for a trace and made it. When I deleted the old trace, a white line appears between an empty place on the PCB and any component labelled GND.
I am unable to remove it and the Design Rules Check flags it as unconnected.
It is not on the schematic! I updated Net List, I’ve refreshed, reloaded, rebooted (lol)
Not sure what is going on there…but sometimes a ratsnest line ending (seemingly nowhere) happens when KiCad wants you to connect to something on a layer which is not presently visible.
Try turning on all of your layers (does not need to be simultaneously) and see if that ratsnest is connecting to something presently hidden.
If you zoom in further you ought to see more net names on the tracks. Sometimes I like to add net labels to my schematic because I dislike labels such as “C27 pin 2” for example.
It seems you have a copper fill (GND I presume). Try to update the copper fill with “B” Hotkey, then the errand white remainder line of the ratsnest should go away
