[SOLVED] Transformer models in simulation
Hi all!
These days I’m playing with kicad 5 rc2 in particular my focus is on the integrated simulator. And it was a nice surprise, it is good even if it is still a child…
After many tests with transistors, diodes and op-amp I’m stuck, due to my incompetence on pspice models, on the transformers.
Is there anyone who can help me?
This isn’t really a KiCad question, so you’re better off searching for PSpice references. For example, a search for “model transformer in pspice” turns up this:
SPICE has no model for an ideal transformer. An ideal transformer is simulated using mutual inductances such that the transformer ratio N1/N2 = sqrt(L1/L2).
Thanks,
I’ve already found a lot of documentation about pspice models. The simplest is the ideal transformer model like this:
.subckt TRAIDE 1 10 2 20
  • a=8
    V1 1 5 DC 0
    ES 5 10 2 20 8
    FS 20 2 V1 8
    .ENDS TRAIDE
But if I link this model to a 4 poles symbol the system doesn’t compile the circuit and the answer is always the same
“Too few parameters for subcircuit type “traide” (instance: xxt1)”
Correct implementation of CENTER-TAPPED TRAFO on KiCAD
using SUBCKT idealized mutual inductance and coupling factor
Paul
Thanks a lot Paul,
your example helped me to found out the solution.
The mistake was in the edited symbol, the pin numbers were excanged with the pin names.
…MEA CULPA…
