Hi!
I’ve just started using KiCad, having experience with other packages. Why is this track highlighted white? I can’t find any mentions to it on the documentation :S
I’m using the latest version on Windows 10 64 bits.
Thanks!
Hi!
Thanks!
There is a highlight track mode.
Activate this tool and click somewhere where nothing is. (This should disable the highlight net tool.)
If this is not the case, press e above the white track and tell us what it says there.
Yes, that did the trick. For whatever reason, that net remained highlighted even when I layed other tracks. I was thinking that I might mean that there was an issue with the track, or that it was not properly connected to the pads.
Thanks!
