After selecting track size and wiring, we cannot change the size, the editor remembers the first one used.
Hello and welcome @Hakim
Need your OS and Kicad version to answer.
Also, you mention track size and wiring… which one?
Hello jmk,
I have kicad 6.02 and win10.
let’s say i have a track with 0.5 mm and then i deleted it, if i redraw the track with another width (1mm), it will take the last one, that is 5mm not 1mm if it is wired to another part having 0.5mm.
Click on this icon before changing track width. The explanation will show when you hover over this.
You may also increase or decrease track sizes according to your predetermined track sizes by using hotkeys SHIFT + W or W. Each press of the hotkey will take you to the next size.
It worked, many thanks.
