A plate is to be made
( picture 1 ):
which fits over the shaft ( picture 2 ):
only there problem as you can see, that is not taken over at picture 3,
Is there a possibility or a trick, because one comes there no further…
Greetings
( picture 1 ):
Greetings
You need to use the Edge.Cuts layer for the central cut out, not just the outline.
Thanks for your Response
I know and already do. problem is. circle inside circle outside works perfectly. but kiCad 7 does not make a circle on the outside and taper on the inside
You must use the Edge.Cuts layer for the central cut, not just the outline.
It was done, but doesn’t work that way.
So edge.cut no matter how does not work…
Here for testing und Downloading .rar file
You can now attach the file directly.
Look in 3D . . .
Then run the DRC . . .
Then look at your footprint . . .
You need to use lines . . . not rectangles.
Problem found, lines 1, 2 and 3 must not be single lines, as continuous lines it works. Thank you for everything
You are most welcome
