[Solved] Something wrong in adding Via when drawing metal lines
Hi everyone.
I’m a new guy using Kicad 7.0. I encountered a problem when I was drawing metal lines.
when I drew a top metal layer’s line, I press “V” in keyboard, there is no via appeared. Only changed to the bottom line (using two-layer board). I’ve checked and tried lots of ways and I can not solve this problem.
Is there anyone who encountered this problem? Please help.
Thanks a lot.
Are you routing traces, or just drawing lines?
I suspect it only works if you are using the trace tool.
Many thanks, my pal. It is solved, thanks a lot. :smiling_face_with_tear:
Yes I think the key is that KiCad calls them “tracks”. If you are drawing “lines” you are probably getting graphic lines that are not intended for electrical connectivity.
Just like you said, 3Dogs have answered my problems. Thanks, pal.
