[SOLVED] Silk screen rotation only 90 and 0 degrees
KiCad 7.0.5 Ubuntu 23.04 I have a board where some silk screen text needs to be readable from the left and some from the right, But -90 and 90 degrees give the same result and 180/0 also the same It happens on top and bottom side. Mirror horizontal or vertical does not have any effect.
Well I deleted the text and did it again, Now it’s ok, Not sure what happened.
Found it, disable, “keep upright” in properties. :slight_smile:
Thanks for posting about Keep Upright. Thought I was going crazy.
