Is there a function to re-read circuit diagram symbols?
Grüße
Can you explain more about what you mean / what you are trying to do? I don’t understand what is meant by “re-read” without any context.
I can re-read an internet browser with CTRL+R, and it works the same way with SpeedCommander and other programs. But I can’t find a function in KiCad if I have explicitly changed symbols using the symbol editor.
I would like to see the changes in all the circuit diagrams.
The “update symbols from library” command is probably what you are looking for?
you should do: select the symbol, right click, update symbol.
There are some configuration on the window that defines the behavior of the command on the schematic.
Thanks, yes you can even update all the symbols there. Exactly what I was looking for.
