hello,
I have the need to represent a horizontal TO-220 THT package with an AAVID Thermalloy 577102B00000G (19x13 mm.) heatsink under it.
To accomplish this task, I have first created a new horizontal TO-220 footprint with the heatsink contour around it. So far, so good.
Nevertheless, a first sign of the problem pops out in the 3D tab of the footprint, where it’s evident that the metal tab of the TO-220 package is not visible:
After having saved the footprint all the same, I have updated the PCB and I have observed the result in the 3D viewer.
While the plastic body of the TO-220 package is rendered correctly, respecting the thickness of the heatsink (the following two images show the right part, near the pins)…
…the metal tab of the TO-220 is literally melted inside the heatsink, as shown in the last image:
For the TO-220 part, I have used the standard model supplied with KiCad, while for the heatsink I have downloaded a 3D model available on Mouser (.step format).
What is wrong with my attempt? Any help will be appreciated.
Salvatore
